question on updating upper yoke on old a3
hey i’ve got these handlebar / stem combo bars that i hate. and i wanna throw some new bars on this thing. i think i can just replace that triple tree on the top to one with mount brackets? but would like an a35 replacement upper yoke work? and and if i find the top part, do i also need to get like a whole separate couple of brackets too? google’s just trying to sell me shit today so i’m having trouble figuring this all out.
thanks guys
Re: question on updating upper yoke on old a3
also would a puch upper yoke work? also is it called an upper yoke or triple tree? jesus i feel soooo dumb
be gentle with me
I take it you are looking for a new way to mount your current bars. The handle bars themselves are the same for the A3/a35 (I own both), and the only difference is how they are mounted. There may be a conversion kit that has a different bracket that goes on the top of your current forks, but you may be looking at new forks to do this. Idk.
I looked around on treats for you and you might just be looking at a new top plate for your triple tree. Maybe upper and lower triple tree? Idk. Look at the measurements it has and compare to what you’ve got on your ped. Good luck man. Get that rad look!
https://www.treatland.tv/original-OEM-tomos-A35-top-fork-triple-tree-blk-p/oem-tomos-upper-yoke-242005blk.htm
https://www.treatland.tv/tomos-OEM-early-a3-fork-UPPER-YOKE-SILVER-p/tomos-oem-upper-yoke-214828sil.htm
♣Slew Foot♣ /
get the whole front fork assembly with it.
the a3 has a yoke and a35's have a triple tree. the gooseneck is on the old one. you will need the replacement bearing cups and such to make it work, puch ones fit an a3 i believe. a35 bars to an a3 frame that is...
yeah no mine has the triple tree top plate holding the fork together on top and then the bars and stem are one piece (two -but welded together) and it’s like a bicycle stem. there’s a video on youtube of a guy updating old style bars the exact same as mine on a puch and i’m pretty sure it’s the same deal. replace that piece and then you can mount new bars on the new triple tree. i know treats has a new a35 triple tree that’s got a spot for the bars but i was wondering if it’s the same dimensions and if i needed brackets. i think i got it figured out though. i’ll update after parts arrive!
thanks guys
