Re: peugeot 103 no spark
Rebel Moby /
Test each component with a ohm meter. Exciter coils are mostly 1-2ohm, spark coils are 1-2hm across the primary and 3500-4500k testing the secondary to common terminal. Check points with no wires attached for go-no go continuity by opening closing contacts. Check the condenser if it will charge and unload with a ohm meter. (or if CDI check trigger coil 1-2ohm). Antiparasite cap should be 5ohm and dont use one if you are using a resistor spark plug.
USA wiring schemes have the core end of the windings on the ignition coil grounded via the tail light circuit or horn or brakes. Check the wiring diagram for which scheme or make a jumper from the core end to common (ground).
  peugeot 103 no sparkTopic by: name vitals name vitals 06/17/18 07:30PM
  Re: peugeot 103 no sparkRe: pat splat pat splat 06/17/18 10:57PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/17/18 11:23PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:15AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:29AM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/18/18 12:37AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:41AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/17/18 11:40PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/17/18 11:46PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 07:57PM
  Re: peugeot 103 no sparkRe: P D P D 06/18/18 08:09PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 08:49PM
  Re: peugeot 103 no sparkRe: P D P D 06/18/18 09:12PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 09:22PM
  Re: peugeot 103 no sparkRe: P D P D 06/19/18 12:54AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/25/18 02:25PM
  Re: peugeot 103 no sparkRe: P D P D 06/25/18 05:07PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/18/18 09:18PM
  Re: peugeot 103 no sparkRe: pat splat pat splat 06/18/18 09:27AM
  Re: peugeot 103 no sparkRe: Angela Cutshaw Angela Cutshaw 03/27/20 01:55PM
  Re: peugeot 103 no sparkRe: Rebel Moby Rebel Moby 03/28/20 09:32AM
