Re: peugeot 103 no spark
cheetahchrome . /
That original red 5mm plug cable screws into little barbed spikes that are in the ends of both that coil and the original boot. If they get corroded or burned they can be trouble.
You can unscrew the wire ans snip off a 1/4 inch to get fresh wire.
Also since you have your friends meter do this:
Remove just the white wire frome the points lug but leave the black condenser wire in place. Put a slip of paper between the points contact. Now use the meter to test for continuity between the points lug and the stator plate. You should have NO continuity. If you have any reading at all it means that your condenser or your points are internally grounded and wont work.
If you dont know how to set your meter to test for continuity just ask. (edited)
  peugeot 103 no sparkTopic by: name vitals name vitals 06/17/18 07:30PM
  Re: peugeot 103 no sparkRe: pat splat pat splat 06/17/18 10:57PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/17/18 11:23PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:15AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:29AM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/18/18 12:37AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 12:41AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/17/18 11:40PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/17/18 11:46PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 07:57PM
  Re: peugeot 103 no sparkRe: P D P D 06/18/18 08:09PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 08:49PM
  Re: peugeot 103 no sparkRe: P D P D 06/18/18 09:12PM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/18/18 09:22PM
  Re: peugeot 103 no sparkRe: P D P D 06/19/18 12:54AM
  Re: peugeot 103 no sparkRe: name vitals name vitals 06/25/18 02:25PM
  Re: peugeot 103 no sparkRe: P D P D 06/25/18 05:07PM
  Re: peugeot 103 no sparkRe: cheetahchrome . cheetahchrome . 06/18/18 09:18PM
  Re: peugeot 103 no sparkRe: pat splat pat splat 06/18/18 09:27AM
  Re: peugeot 103 no sparkRe: Angela Cutshaw Angela Cutshaw 03/27/20 01:55PM
  Re: peugeot 103 no sparkRe: Rebel Moby Rebel Moby 03/28/20 09:32AM
