> mike sweet Wrote:
> 60s range of jets is the plan. Think im gonna go ahead and order the
> Tecno exhaust for it too. Idle is the primary concern right now, so
> hopefully the 30 idle jet solves that. It wont idle whatsoever without
> the choke on. Idle screw all the way in, air/fuel screw in all the way
> as well. More evidence idle is too lean.
> If I kick it over and pull the throttle wide open, then I can get it to
> take off and actually run half way decent (I have a bit of the air
> intake side of the carb taped off behind the filter to restrict air flow
> a little)
I'm not sure replacing the idle jet is going to solve the problem you're describing. By all means change the idle jet but I have a feeling there's something else going on. In my experience poor idling is more to do with carb adjustment/gaskets, electrical or transmission/brake issues than the jet itself.
60's jets into 70's will serve you well. I think I'm running a 68 right now with a Technigas, foam filter and porting. Hope to use the 70's soon as well.
