60s range of jets is the plan. Think im gonna go ahead and order the Tecno exhaust for it too. Idle is the primary concern right now, so hopefully the 30 idle jet solves that. It wont idle whatsoever without the choke on. Idle screw all the way in, air/fuel screw in all the way as well. More evidence idle is too lean.
If I kick it over and pull the throttle wide open, then I can get it to take off and actually run half way decent (I have a bit of the air intake side of the carb taped off behind the filter to restrict air flow a little)
