Like 4 actually ☹ on the kick start for my nu50.
Where can I get replacements??
From eBay only becareful with the washers they only sell one of the 3 and bushings are all but one able to be bought new. Welcome to the club of nu50 kickstart problems you must have a missing washer or bad or missing bushing also must line up dots. Very simple though I've had to take mine apart a ton till I got the washers it was missing. Look up the maunual for correct installation and pics of comments.
Those are Summer teeth.
Summer there. Some ain't.
yeah, that sucks. I bought one like that. I bought replacements off eBay.
How hard were you kicking that thing?
I often wondered how the previous owner did that to mine. Standing on the kickstart?
I welded new ones on before. Welded a section on, then angle grinder new teeth. I was surprise how well it actually worked. Are you looking for a replacement? I might have one.
I'd go with weld some teeth back on! If you've got a MIG welder it wont take too much. Turn the current up high so you get proper penetration. Use an angle grinder with a 0.8 or 1.0mm 'slitting disc' made for stainless steel. carefully cut your teeth! Some 20 years ago I did it on the ring gear of a car, lasted for the rest of the time I owned it!
