Where to find carburetor idle screw for cheapest?
I just bought a PA50i and the carburetor is missing the idle screw and jet. I was wondering where I could buy it for cheapest? The kit on treatland is 30$ which is a bit expensive since I only need 1 screw of the whole kit.
Thanks
Re: Where to find carburetor idle screw for cheapest?
Stock carb?
Yes for the stock carb
you could buy a whole clone carb for 30 and swap parts off of it. or ask in buy sell someone'd probably mail you one even less. I got a pile of old carbs I just mix and match til stuff fits. have also just filed down the tips of bolts on a grinder if you've got bolts that fit the threading (usually extra fine threads tho)
wait isn't the hobbit idle just a stop screw on top of the carb?? it's probably just a standard m4 screw, use any screw/bolt whatever that fits...
Or do you mean the actual air adjustment screw? those are pretty specific and tricky/impossible to shape yourself, but looks like theyre $6 on ebay from china...
first name last name /
So if you get a plane ticket to China you could probably pick one up for about $0.12.
Don't forget your passport.
Thanks, I'll just get a standard M4 screw and I think it will fit. Actually the screw to close the float bowl fits fine in the threadings.
As for the jet, I guess I'll have to figure out which one comes stock with a PA50i and order one.
Thanks !
> about $0.12.
thats a good one. for all the stuff i ordered from china, i should have done that years ago.
i know you just need a coupla bits but got the whole stock carb if your interested. pa50i 25 shipped
