1980 Vespa Grande won't idle/ hard to start
Christopher Ballard /
Just bought a semi running 1980 Vespa Grande Deluxe. It ran and idled when I picked it up but once I got it home its hard to start and won't hold an idle. Once you get below 5 mph it just does. Carb is clean and looks good, spark is fine and has a fresh tank of gas. Gas tank is fine- no rust or water. Any suggestions?
Re: 1980 Vespa Grande won't idle/ hard to start
stick a small wire thru idle hole below throttle slide, carb off.
If the carb was clean then the bike would idle. Take it completely apart again and do what Pat suggests. I usually soak my carbs in Rubbing alcohol 91%, never had an idle issue after that.
Below is the money shot of what Pat is talking about
Hope necro'ing thread OK.
I'm having idle issues (could be from number of things I guess), but pulled off my new carb (I hardly ran it after putting on carb and exhaust last summer due to health problems) and can't find where the idle circuit comes out -- it's a dellorto 12.12 from moped division.
I checked according to Ninja's pic above, but there is no orifice there on this Dellorto. Any help would be great. Just trying to cover all the bases.
Let us see a pic of your carb Eric.
Just like Ninja shows there has to be a idle passage.
Here I have one too
I'll take a pic while I have the carb off tomorrow messing with different jets. I am guessing the idle orifice just in a different place on my new carb, be damned if I know!
If you have the carb intake shim installed, it may obstruct your vision of the idle passage, but it’s there. Gotta be.
There is a shim that females onto the intake, then males into the carb, as well as a rubber o ring. I had both of those pulled and set aside looking. I'll get a pic tomorrow, and triple check in the meantime (I ain't above missing the painfully obvious).
Yeah I just missed it like a dumbass.
Poked it out with a stand from a wire brush, threw in a bigger jet, and copper hooped my exhaust junction. Ran and idled fine today after a little warmup and had a nice ride.
Dominic Colonna /
My grande was sitting around for 40 years.
I disassembled the carburator, cleaned it, the orifice unplugged. The moped starts, but stops idling after a few seconds. It sounds louder then normal moped sound.
Could the points need resetting, or a timing issue or yet carburator issue?
I appreciate any inputs, thanks.
once u report some effort, then report back.
