> Josiah Radebaugh Wrote:
> *sigh* Well it has spark i thing I timed it right. It might sorta try to
> start only if you pedal hard and long but doesn't really with some loud
> back fires pretty often. I'll check the timing again.
And you do have a ground strap going from the engine cases to the Mount of the HT coil and the headlight bucket correct if you don't you will have that back fireing intermittent hell.
1.2 mm on the timing and the spark plug gap should be between 19 and 23 thousandths of an inch.
Timing before jetting or your life will be another hell and a three-page thread on the Forum.
