Re: Peugeot 103 ignition upgrade.
P D /
> Josiah Radebaugh Wrote:
> I don't know the electrical aspect well enough to think that
> definitively. I still don't have spark. Had once removed the flywheel
> and no longer.
Have you tried the basics ?
With the black coil in place and the HT wire to the spark plug .
Disconnect all other wires from/to the stator , except the brown wire , which will be used to kill the motor , if you try to run it . Leave the brown wire bare ended hooked to nothing , but able to reach a good ground point . There should be no switches or tail light connected .
The white wire can be hooked to the terminal on the points , which also has a wire going to the condenser . Those should be the only wires hooked to the points . Remember , the brown wire is hooked to the condenser .
Be sure that the black wire on the condenser , the one not going to the points , is insulated from everything or remove it .
Insure the points are alcohol clean and gaped correctly and timed correctly . Insure the spark plug is thoroughly grounded . With the flywheel in place , spin the crankshaft . Hopefully you should see a fat blue/whitish spark .
Good Luck .
  Peugeot 103 ignition upgrade.Topic by: Josiah Radebaugh Josiah Radebaugh 06/02/18 08:35PM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/03/18 10:32AM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 06:56PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 01:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 02:10PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 08:34PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 10:22PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/05/18 12:26PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/05/18 10:01PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/06/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Kenneth Hill Kenneth Hill 06/05/18 12:34AM
  Re: Peugeot 103 ignition upgrade.Re: Dirty30 Dillon Dirty30 Dillon 06/05/18 12:50PM
  Re: Peugeot 103 ignition upgrade.Re: P8R . P8R . 06/06/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/06/18 02:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/07/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/15/18 01:42PM
  Re: Peugeot 103 ignition upgrade.Re: Dirty Mike Dirty Mike 06/15/18 04:05PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/15/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/15/18 05:50PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/16/18 10:34PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:37PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:49PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/16/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 11:13AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/17/18 11:34AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 12:57PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/18/18 11:57PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/19/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/19/18 10:18AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/20/18 02:06PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/20/18 11:46PM
  Re: Peugeot 103 ignition upgrade.Re: Larry 969 Larry 969 06/21/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/22/18 01:14AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 04:30PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 05:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 06:51PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 04:55PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 05:38PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:21PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:52PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 08:59PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 09:05PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/23/18 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/24/18 09:53AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 03:22PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 05:15PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 05:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 06:16PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 07:18PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 07:53PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 08:11PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 10:00PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 10:33PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/26/18 01:32PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:39PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 02:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/26/18 01:55PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 01:21AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:43AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 09:24AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 09:45AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 10:36AM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 02:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 04:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 05:10PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 06:46PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 07:19PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:09PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 08:26PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 10:56PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 11:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 11:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 11:40AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/04/18 12:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 12:32PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 12:58PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 02:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 02:13PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 03:11PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 04:15PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:09PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:14PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:42PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:55PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 06:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/07/18 09:37PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 11:06AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 12:05PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 07/03/18 12:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 12:14PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/04/19 08:32PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 12:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 07:50PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:36PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:57PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 09:44PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:51PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 03:09PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 04:49PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 05:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 07:01PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 12:46AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 08:17AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 09:39AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 11/06/19 10:45AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 10:57AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 11:17AM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 01:28PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 02:51PM
