Re: Peugeot 103 ignition upgrade.
cheetahchrome . /
Assuming you have the stock Gurter carb and air box installed, your four stroke issue could be coming from your choke not coming off all the way.
The choke lever or cable linkage on the back of the carb can often get bent or be rubbing on the rim of the airbox.. With your side covers off, Reach in and pull the choke linkage cable stop out of the choke lever fork so that you can then check for full range of travel of the choke lever ans you can feel that the choke spring is indeed acting on the lever.
When confident you have full travel you can eliminate the choke as cause of this 4 stroke.
If you think the bike is running lean well then you should screww out your main jet from the side of the carb and make certain that it is completely clean.
You do not have to remove your carb to get at the main jet.
  Peugeot 103 ignition upgrade.Topic by: Josiah Radebaugh Josiah Radebaugh 06/02/18 08:35PM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/03/18 10:32AM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 06:56PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 01:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 02:10PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 08:34PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 10:22PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/05/18 12:26PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/05/18 10:01PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/06/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Kenneth Hill Kenneth Hill 06/05/18 12:34AM
  Re: Peugeot 103 ignition upgrade.Re: Dirty30 Dillon Dirty30 Dillon 06/05/18 12:50PM
  Re: Peugeot 103 ignition upgrade.Re: P8R . P8R . 06/06/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/06/18 02:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/07/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/15/18 01:42PM
  Re: Peugeot 103 ignition upgrade.Re: Dirty Mike Dirty Mike 06/15/18 04:05PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/15/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/15/18 05:50PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/16/18 10:34PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:37PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:49PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/16/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 11:13AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/17/18 11:34AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 12:57PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/18/18 11:57PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/19/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/19/18 10:18AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/20/18 02:06PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/20/18 11:46PM
  Re: Peugeot 103 ignition upgrade.Re: Larry 969 Larry 969 06/21/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/22/18 01:14AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 04:30PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 05:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 06:51PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 04:55PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 05:38PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:21PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:52PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 08:59PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 09:05PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/23/18 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/24/18 09:53AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 03:22PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 05:15PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 05:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 06:16PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 07:18PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 07:53PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 08:11PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 10:00PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 10:33PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/26/18 01:32PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:39PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 02:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/26/18 01:55PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 01:21AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:43AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 09:24AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 09:45AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 10:36AM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 02:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 04:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 05:10PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 06:46PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 07:19PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:09PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 08:26PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 10:56PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 11:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 11:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 11:40AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/04/18 12:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 12:32PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 12:58PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 02:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 02:13PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 03:11PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 04:15PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:09PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:14PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:42PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:55PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 06:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/07/18 09:37PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 11:06AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 12:05PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 07/03/18 12:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 12:14PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/04/19 08:32PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 12:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 07:50PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:36PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:57PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 09:44PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:51PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 03:09PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 04:49PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 05:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 07:01PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 12:46AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 08:17AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 09:39AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 11/06/19 10:45AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 10:57AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 11:17AM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 01:28PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 02:51PM
