Re: Peugeot 103 ignition upgrade.
cheetahchrome . /
WAIT WAIT WAIT!! I just went back and read the original post. You said you fear your stock coils may be going out soon?!? You mean your original ignition is working but you want to tear it all out because you FEAR that it could go out soon?
That is like when you clean up your garage and you throw away a quart of oil because it's old.
Don't stare out of a window at your bike on a cloudy day for fear of rain.
All of the replacement internal coils suggested here lack the floated ground wire feature that would normally power your brake lights. Yes you will want brake lights the day after you install the aftermarket internal coil and the bike runs.
Now to get brake lights back you have to leach power from your Red head light wire, replace both your brake light switches, Eliminate the grounding wire in the headlight and route that wire back down the frame to your black brake light wire.
Then when your all done it sucks because the brake light causes the headlight to dim when you apply the levers.
To cure that you start fucking with LED tailights but those want to blow cause the need a diode installed to soften the AC wave.
It's a whole fuck storm of things you have to do that is called the moped hobby that is best experienced by just trying to learn to make all of your stock features work correctly at first and understand why they behave the way they do.
I have found over the years maybe 2 Peugeot stock ignitions that were bad. I try to run the stock points sets on all the bikes I refurbish for sale.
By the way does your bike start and run now?
  Peugeot 103 ignition upgrade.Topic by: Josiah Radebaugh Josiah Radebaugh 06/02/18 08:35PM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/03/18 10:32AM
  Re: Peugeot 103 ignition upgrade.Re: Sir Clip Sir Clip 06/03/18 06:56PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 01:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 02:10PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/04/18 08:34PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/04/18 10:22PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/05/18 12:26PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/05/18 10:01PM
  Re: Peugeot 103 ignition upgrade.Re: Thierry Marseille Thierry Marseille 06/06/18 07:51AM
  Re: Peugeot 103 ignition upgrade.Re: Kenneth Hill Kenneth Hill 06/05/18 12:34AM
  Re: Peugeot 103 ignition upgrade.Re: Dirty30 Dillon Dirty30 Dillon 06/05/18 12:50PM
  Re: Peugeot 103 ignition upgrade.Re: P8R . P8R . 06/06/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/06/18 02:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/07/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/15/18 01:42PM
  Re: Peugeot 103 ignition upgrade.Re: Dirty Mike Dirty Mike 06/15/18 04:05PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/15/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/15/18 05:50PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/16/18 10:34PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:37PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 06/16/18 10:49PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/16/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 11:13AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/17/18 11:34AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/17/18 12:57PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/18/18 11:57PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/19/18 09:56AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/19/18 10:18AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/20/18 02:06PM
  Re: Peugeot 103 ignition upgrade.Re: Rocco Taco Rocco Taco 06/20/18 11:46PM
  Re: Peugeot 103 ignition upgrade.Re: Larry 969 Larry 969 06/21/18 10:54PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 01:05AM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/22/18 01:14AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 04:30PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/22/18 05:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/22/18 06:51PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 04:55PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 05:38PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:21PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 06/26/18 06:52PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 06:54PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 08:59PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/02/18 09:05PM
  Re: Peugeot 103 ignition upgrade.Re: jumpsuit steve jumpsuit steve 06/23/18 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/24/18 09:53AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 03:22PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 05:15PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 05:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 06:16PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 07:18PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 07:53PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 08:11PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/25/18 10:00PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/25/18 10:33PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 06/26/18 01:32PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 01:39PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 06/26/18 02:04PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 06/26/18 01:55PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 01:21AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:43AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 09:24AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 09:45AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 10:36AM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 02:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 04:51PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 05:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 05:10PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 06:43PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 06:46PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 07:19PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 08:09PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 08:26PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 10:56PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/03/18 11:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 11:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 11:40AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/04/18 12:11PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 12:32PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 12:58PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 02:02PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 02:13PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 03:11PM
  Re: Peugeot 103 ignition upgrade.Re: cheetahchrome . cheetahchrome . 07/04/18 04:15PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:09PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:14PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:23PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:42PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 05:45PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/04/18 05:55PM
  Re: Peugeot 103 ignition upgrade.Re: Crazy Wayne Crazy Wayne 07/04/18 06:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/07/18 09:37PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 11:06AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 07/03/18 12:05PM
  Re: Peugeot 103 ignition upgrade.Re: simon judd simon judd 07/03/18 12:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 07/03/18 12:14PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/04/19 08:32PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 12:08PM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 07:50PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:36PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:57PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 09:44PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 10/11/19 08:51PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 03:09PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 04:49PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 05:07PM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/05/19 06:45PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 07:01PM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 12:46AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 08:17AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 09:39AM
  Re: Peugeot 103 ignition upgrade.Re: Josiah Radebaugh Josiah Radebaugh 11/06/19 10:45AM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 10:57AM
  Re: Peugeot 103 ignition upgrade.Re: P D P D 11/06/19 11:17AM
  Re: Peugeot 103 ignition upgrade.Re: Rufus Von Rieles Rufus Von Rieles 11/06/19 01:28PM
  Re: Peugeot 103 ignition upgrade.Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/06/19 02:51PM
