Re: Puch 12volt LED light conversion
Lee Snover /
> Brad William Wrote:
> https://www.homedepot.com/p/Philips-50-Watt-Equivalent-MR16-Dimmable-LED-Light-Bulb-Glass-470278/302187933
> This is the pair that I have currently on the bike. 7.5 x 2 = 15. 15
> watts is reported to be the max output of the oem e50 (I said za50 above
> but I meant e50).
> The bulb I linked to in the above post is 8.5w. 17w ought to be fine for
> the e50.. we'll see in the future. But the beam is rated (by the same
> company) at 90 lumens brighter, 10 degrees narrower, and 1000k whiter so
> it ought to be a noticeable improvement. As mentioned previously,
> Philips mounts these leds on a round heatsink-circuit board with all the
> circuitry they feel necessary to safeguard these bulbs against the range
> of crap low voltage ac that landscapers are liable to throw at them.
> Surely a 1984 howling vibration maker of a moped engine is at the bad
> end of that range.... nonetheless they've survive it just fine.
> As to the original poster, YMMV of course, but these are grounded to
> frame with no negative effects for two pretty high mileage summers now.
So you can install this in the stock headlight housing? It will work at 6v, or you need to upgrade to12v? It doesn't cause issues with the rest of the electrical system?
  Puch 12volt LED light conversionTopic by: Triflin Milton Triflin Milton 05/24/18 10:54PM
  Re: Puch 12volt LED light conversionRe: Bad Cadillac™ Bad Cadillac™ 05/25/18 06:56AM
  Re: Puch 12volt LED light conversionRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/25/18 07:09AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 10:03AM
  Re: Puch 12volt LED light conversionRe: Marc Friedman Marc Friedman 05/25/18 10:58AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 11:04AM
  Re: Puch 12volt LED light conversionRe: Dirty30 Dillon Dirty30 Dillon 05/25/18 01:09PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 01:17PM
  Re: Puch 12volt LED light conversionRe: Thierry Marseille Thierry Marseille 05/27/18 06:36AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/26/18 10:55PM
  Re: Puch 12volt LED light conversionRe: frank dadog frank dadog 05/28/18 01:34PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/28/18 01:35PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 06/03/18 09:17PM
  Re: Puch 12volt LED light conversionRe: P D P D 06/03/18 10:59PM
  Re: Puch 12volt LED light conversionRe: Marc Friedman Marc Friedman 05/27/18 01:29AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/27/18 02:13AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/27/18 02:51AM
  Re: Puch 12volt LED light conversionRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/27/18 07:25AM
  Re: Puch 12volt LED light conversionRe: Ungapped rings to bind them all Ungapped rings to bind them all 05/27/18 09:02AM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 06/06/18 06:58PM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 06/08/18 04:03PM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/17/19 12:16AM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/15/19 10:36AM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 08/16/19 04:17PM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/16/19 11:03PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 08/16/19 04:48PM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 08/16/19 06:34PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 08/17/19 11:12AM
