Re: Puch 12volt LED light conversion
Triflin Milton /
> Lee Snover Wrote:
> I know almost zero about electrical. I tried an LED sealed beam and
> small LED tail lights. Light lasted about 2 weeks and died and took
> that the tail LED.
> What do you all mean about "floating" a ground to AC. Don't ground to
> chassis? Details appreciated.
> If there is a non LED headlight bulb that works in the stock light and
> is better/best, please share a link for me! Appreciate!
By float I mean do not ground to chassis. The plug is getting AC. Everything else grounded to the chassis runs off of AC.
I got a 12v light coil and ran it through a trail tech regulator rectifier before the led lights. LED lights will not run well on AC and will burn out quickly. This is 12v DC coming off the reg rec. Do not ground this circuit to the chassis. Mixing grounding of AC and DC is a bad idea. Simply route the black wires back to the reg rec. So float it. Meaning it is not grounded, but the circuit is complete.
For my tail and brake lights I just got cheap bulbs off amazon that had the same base. The headlight is actually intented for a tractor. I dont have the link anymore but its friggin bright as hell. Do a little searching and you'll see which brand I'm talking about.
In a nutshell. To run led lights, get a 12v light coil. Use a reg rec to convert to DC. Float the circuit.
My rig had worked solid for about a year with no issues.
  Puch 12volt LED light conversionTopic by: Triflin Milton Triflin Milton 05/24/18 10:54PM
  Re: Puch 12volt LED light conversionRe: Bad Cadillac™ Bad Cadillac™ 05/25/18 06:56AM
  Re: Puch 12volt LED light conversionRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/25/18 07:09AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 10:03AM
  Re: Puch 12volt LED light conversionRe: Marc Friedman Marc Friedman 05/25/18 10:58AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 11:04AM
  Re: Puch 12volt LED light conversionRe: Dirty30 Dillon Dirty30 Dillon 05/25/18 01:09PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/25/18 01:17PM
  Re: Puch 12volt LED light conversionRe: Thierry Marseille Thierry Marseille 05/27/18 06:36AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/26/18 10:55PM
  Re: Puch 12volt LED light conversionRe: frank dadog frank dadog 05/28/18 01:34PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/28/18 01:35PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 06/03/18 09:17PM
  Re: Puch 12volt LED light conversionRe: P D P D 06/03/18 10:59PM
  Re: Puch 12volt LED light conversionRe: Marc Friedman Marc Friedman 05/27/18 01:29AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/27/18 02:13AM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 05/27/18 02:51AM
  Re: Puch 12volt LED light conversionRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/27/18 07:25AM
  Re: Puch 12volt LED light conversionRe: Ungapped rings to bind them all Ungapped rings to bind them all 05/27/18 09:02AM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 06/06/18 06:58PM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 06/08/18 04:03PM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/17/19 12:16AM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/15/19 10:36AM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 08/16/19 04:17PM
  Re: Puch 12volt LED light conversionRe: Lee Snover Lee Snover 08/16/19 11:03PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 08/16/19 04:48PM
  Re: Puch 12volt LED light conversionRe: Brad William Brad William 08/16/19 06:34PM
  Re: Puch 12volt LED light conversionRe: Triflin Milton Triflin Milton 08/17/19 11:12AM
