Re: Rolls but staggers and won't start
Aaron Blair /
put it on the stand with the wheel off the ground. turn the pedal very slowly. if you can feel the engine trying to turn over. then your starter clutch is stuck in the engaged position.
you should have to pedal faster or kick hard to swing out the centrifugal starter clutch.
