Is there a chain tension that goes on my moped?
Emmett Hopper /
The moteriazed chain is loose and I need to know how to order a chain tightner
Any help??
77 Batavus trike 49cc motor
Re: Is there a chain tension that goes on my moped?
if theres no adjustment, u might be able to cut out a link and add a half link to snug up.
It is hard to tell by the pic. Does the rear section have adjustments. Like the whole thing may slide back. The Pyle (I think that is how it is spelled). Has a couple bolts you losen they, slide it back till the chain is tight then tighten them down.
If it doesn’t you may ant to try and make a chain tensioner. Maybe look into modifying a pit bike one or something.
