Snowflake sealed bearing conversion
I converted my Puch snowflake rims to sealed bearings, and I noticed my rear wheel when mounted is dragging a bit. Don't know if I have a spacing problem, or what, because when the wheel is off, it spins freely and smoothly on the axle. What can I do to help?
Re: Snowflake sealed bearing conversion
Charles Cole (OFMC) /
There has to be a spacer, between the bearings, for them to spin freely when the axle nuts are tightened. It's length has to be very precise.
^^^ yes!
Also check to see if you spaced the brake plate properly. I had that problem before. If that is what it is, just keep adding washers or spacers until it doesn’t drag anymore.
