Re: Fa50 won't fire after kickstart lock
Born to be WillD /
is it sparking? More than just checking for spark, if you're kicking and it's sparking you can be sure everything's turning over.
then run it thru the freds guide. hit it with some starter fluid and see if its a fuel issue.
but I believe from your details you've got a trans issue where your kicker isn't turning things over. I'd be inclined to check on the chain (should be a lil internal chain drive I think) and gears
