I had something similar happen. I had to change to the leaner needle, and mess with the needle clip setting. Down size the jet and get the correct gas ratio from the needle and clip setting. That should do it for you. Try every setting to dial it in. Good luck and record your settings on paper so you don’t repeat settings you’ve already tried.
