Re: Tomos sprocket same size as Italian sprocket?
cheetahchrome . /
Yes to what Blake says. The biggest concern is you absolutely must match up the center of the sprocket to the wheel hubs relief. then you can try to dremmel the bolt holes. If the center fit is off even a millimeter you will hate life later as the chain will whip like crazy and vibrate the bike all over.
