Tomos sprocket same size as Italian sprocket?
Sloetwn Suv Stigmopeyass /
Anyone know if tomos sprockets are interchangeable for Italian 4 bolt varieties?
Re: Tomos sprocket same size as Italian sprocket?
i think its close, u just gotta slot it a little w dremel.
There are multiple Italian sprocket patterns. Tomos is reasonably close to some. Just what I have on the shelf are 5 or so different bolt patterns and 3 different center hole sizes. It's a pretty common swap but not always a bolt and go solution.
Yes to what Blake says. The biggest concern is you absolutely must match up the center of the sprocket to the wheel hubs relief. then you can try to dremmel the bolt holes. If the center fit is off even a millimeter you will hate life later as the chain will whip like crazy and vibrate the bike all over.
