Re: Peugeot 103 Float problems. Again.
Rebel Moby /
Excellent
> Josiah Radebaugh Wrote:
> Alright so I figured out the problem. You all mentioned the float perch
> being dirty which I didn't think was the problem at first. The float
> cover had fuel flow and the float was all good. I remembered that a have
> a second carbeuetor that I bought off Dusty Rim awhile back just to have
> the float mainly, so i compared the two and realized that the extra carb
> I could see to the bottom of the float perch but mine I couldnt. So I
> sprayed some WD-40 into the bowl and cleaned the hole with a tiny drill
> bit. So it turned out that all the fuss was caused because of some dry
> rust powder in the bottom of the bowl! I will need to buy a spark plug
> though. Thanks all!
  Peugeot 103 Float problems. Again.Topic by: Josiah Radebaugh Josiah Radebaugh 01/27/18 04:40PM
  Re: Peugeot 103 Float problems. Again.Re: Moped Lar (OFMC) Moped Lar (OFMC) 01/27/18 04:54PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/27/18 05:22PM
  Re: Peugeot 103 Float problems. Again.Re: Trevor Perez Trevor Perez 09/12/19 06:53PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/27/18 08:58PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 09:23AM
  Re: Peugeot 103 Float problems. Again.Re: P D P D 01/28/18 09:53AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 11:40AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 12:04PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 09:59AM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 10:33AM
  Re: Peugeot 103 Float problems. Again.Re: pat splat pat splat 01/28/18 12:43PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 01:59PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 05:52PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 06:45PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 07:31PM
  Re: Peugeot 103 Float problems. Again.Re: Dusty Rim Dusty Rim 01/29/18 03:25PM
