Re: Peugeot 103 Float problems. Again.
Josiah Radebaugh /
Alright so I figured out the problem. You all mentioned the float perch being dirty which I didn't think was the problem at first. The float cover had fuel flow and the float was all good. I remembered that a have a second carbeuetor that I bought off Dusty Rim awhile back just to have the float mainly, so i compared the two and realized that the extra carb I could see to the bottom of the float perch but mine I couldnt. So I sprayed some WD-40 into the bowl and cleaned the hole with a tiny drill bit. So it turned out that all the fuss was caused because of some dry rust powder in the bottom of the bowl! I will need to buy a spark plug though. Thanks all!
  Peugeot 103 Float problems. Again.Topic by: Josiah Radebaugh Josiah Radebaugh 01/27/18 04:40PM
  Re: Peugeot 103 Float problems. Again.Re: Moped Lar (OFMC) Moped Lar (OFMC) 01/27/18 04:54PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/27/18 05:22PM
  Re: Peugeot 103 Float problems. Again.Re: Trevor Perez Trevor Perez 09/12/19 06:53PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/27/18 08:58PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 09:23AM
  Re: Peugeot 103 Float problems. Again.Re: P D P D 01/28/18 09:53AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 11:40AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 12:04PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 09:59AM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 10:33AM
  Re: Peugeot 103 Float problems. Again.Re: pat splat pat splat 01/28/18 12:43PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 01:59PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 05:52PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 06:45PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 07:31PM
  Re: Peugeot 103 Float problems. Again.Re: Dusty Rim Dusty Rim 01/29/18 03:25PM
