Peugeot 103 Float problems. Again.
Josiah Radebaugh /
A wile back I had asked about the original float having a leak. So I bought a new-ish one. I removed the old float and put in the new float. Put more gas in the tank and then tried to start it. It usually starts within 2-5 kicks but this time I kicked about 20 times, nothing. I tried pedaling it down my driveway to start it, nothing. I checked for spark and all was good. So I removed the fuel line and opened the petcock to verify fuel flow and there was. So I decided to remove the entire carbeuetor to check things out, once off I blew into the fuel IN and there was no air flow. I removed the top of the bowl and the carbeuetor was dry.If I remove the float there is no problem with air or liquid passing through but as soon as I put the float back in it acts as if the float it stuck in the closed position allowing nothing past. So do any of you know what's happening here?
  Peugeot 103 Float problems. Again.Topic by: Josiah Radebaugh Josiah Radebaugh 01/27/18 04:40PM
  Re: Peugeot 103 Float problems. Again.Re: Moped Lar (OFMC) Moped Lar (OFMC) 01/27/18 04:54PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/27/18 05:22PM
  Re: Peugeot 103 Float problems. Again.Re: Trevor Perez Trevor Perez 09/12/19 06:53PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/27/18 08:58PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 09:23AM
  Re: Peugeot 103 Float problems. Again.Re: P D P D 01/28/18 09:53AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 11:40AM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 12:04PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 09:59AM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 10:33AM
  Re: Peugeot 103 Float problems. Again.Re: pat splat pat splat 01/28/18 12:43PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 01:59PM
  Re: Peugeot 103 Float problems. Again.Re: Rebel Moby Rebel Moby 01/28/18 05:52PM
  Re: Peugeot 103 Float problems. Again.Re: cheetahchrome . cheetahchrome . 01/28/18 06:45PM
  Re: Peugeot 103 Float problems. Again.Re: Josiah Radebaugh Josiah Radebaugh 01/28/18 07:31PM
  Re: Peugeot 103 Float problems. Again.Re: Dusty Rim Dusty Rim 01/29/18 03:25PM
