How do I connect my ignition coil on my 1996 tomos st
quinn nascimento /
I need help getting everything wired up correctly
Re: How do I connect my ignition coil on my 1996 tomos st
quinn nascimento /
This is the side of the engine
Richard Eberline /
get on the computer and look up your wiring diagram.
mounts on two holes under zip tie.
You need to get some shrink wrap, some wire, and some spade terminals to sort out that hacked up wiring. If you don't it's going to give you headaches. You need to remove that duct tape and see what's hiding in there. The black wire with the female spade terminal that comes out of the stator goes to the wiring harness where that duct tape is. There is also a black wire with a female spade terminal that comes from that same spot on the harness which plugs into the cdi unit. Then you'll need to ground the brown wire from the cdi to a clean bare metal spot on the chassis. The wiring harness should also have a brown ground wire with a ring terminal that you can ground to the same spot. The yellow wire is for the lights which obviously needs work too, but the motor will run without that for now.
