Re: Pa50-II cdi to points swap issue.
david carroll /
I did replace the cam thing that holds the magneto. The cdi one doesn't have the lump for the points to open. But I did happen to figure it out just after posting this. My newly swapped points weren't gap enough and firing to late..found that because it was only sparking going in reverse or clockwise with the drill.
Click here to login.
