Re: Pinto- 1 to no spark
P D /
> Double Trouble Dan Wrote:
> Ya screwed up the wiring . Its grounding out.
> Fix it or wire direct.
> Then file the points . Spray electrical contact cleaner or MAF cleaner
> on them.
> If it still does not spark , do it again.
> If you can , remove the flywheel and sand all magnets.
> Problem solved.
I usually finish cleaning a set of points , after using your stated method , with a clean , crisp dollar bill . That is just abrasive enough to remove any leftover particles that might hinder contact .
Always remember that it only takes a finger print to foil a set of points .
Click here to login.
