1980 Tomos A3 6v points to 12v cdi conversion
Kristoffer Johnson /
Posting up my notes on converting a 1980 Tomos Bullet A3 with 6v points to 12cdi. Perhaps someone else may find them useful.
Parts needed at least what I bought
CDI kit from moped junkyard
12v regulator, Horn, and all bulbs
Momentary switches (off when at rest) for the brake levers
You will also need to disconnect the 6v resistor under the taillights.
What will get hacked up in the process is highlighted in orange.
What the end result will be.
Hope that helps someoneEdited 2 time(s). Last edit at 12/31/17 04:49PM by wisconsinkris.
Click here to login.
