Re: How much fork oil for Hydro General Forks
DrGeorgeTompson (Alan) /
> Baron Von Hamilton Wrote:
> On lots of older bike the manuals call for using ATF. Idk if fork oil
> was not a thing or it was hard to get or what.
Probably a case of "hey that's easy to find. have them use that" when really it doesn't matter too much as long as its not gonna foam up.
> Supposedly it is close
> to 10w and has a seal conditioning agents and anti foam properties that
> are similar to fork oil. I may still use fork oil but don’t feel like
> spending $20 to only use a little bit once. I have more than enough ATF.
> Closest light weight oil I have is 30w.
I think i'm just prone to thinking atf is nasty because of stupid Garelli clutches.
I have a mostly full bottle of 5 weight Motul fork oil I will never use if you wanna try it. I think that's way too light though.
I put 10w-30, that mobil 1 wet clutch catchall racing motorcycle schmoo, in my K10 forks and that's nowhere near stiff enough for my liking. I should try adding more fluid one of these days to see I can make them suck a little less. I think more volume helps reduce bottom-out but I also want more rebound dampening which I think can only be adjusted by oil weight on the old timey stuff without dials and knobs. I'll mess with it some more come springtime.
  How much fork oil for Hydro General ForksTopic by: Baron Von Hamilton Baron Von Hamilton 12/31/17 10:38AM
  Re: How much fork oil for Hydro General ForksRe: Mikey Antonakakis Mikey Antonakakis 12/31/17 10:46AM
  Re: How much fork oil for Hydro General ForksRe: P D P D 12/31/17 12:14PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 12/31/17 02:50PM
  Re: How much fork oil for Hydro General ForksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/31/17 02:35PM
  Re: How much fork oil for Hydro General ForksRe: P D P D 12/31/17 02:55PM
  Re: How much fork oil for Hydro General ForksRe: Mikey Antonakakis Mikey Antonakakis 12/31/17 03:21PM
  Re: How much fork oil for Hydro General ForksRe: Full Tuck Full Tuck 12/31/17 03:29PM
  Re: How much fork oil for Hydro General ForksRe: P D P D 12/31/17 08:53PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 01:45PM
  Re: How much fork oil for Hydro General ForksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/03/18 01:51PM
  Re: How much fork oil for Hydro General ForksRe: P D P D 01/03/18 02:40PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 02:39PM
  Re: How much fork oil for Hydro General ForksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/03/18 02:57PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 05:01PM
  Re: How much fork oil for Hydro General ForksRe: P D P D 01/03/18 05:37PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 05:57PM
  Re: How much fork oil for Hydro General ForksRe: P D P D 01/03/18 07:51PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 09:26PM
  Re: How much fork oil for Hydro General ForksRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 09:53PM
Click here to login.
