Re: Clogged Bystarter Orfice
P D /
You might try cutting a single wire from a wire brush . use needle nose pliers to hold it and run the wire through orifice . Don't get too carried away , just enough that you get decent flow through . You don't want to enlarge the hole , just clear it .
Click here to login.
