Re: Tomos LX leaking transmission oil
Marc Friedman /
Maya what : what volume of tranny fluids are you using. As I posted elshere about delaying shift point with larger volumes of tranny fluids , mine reliably leaks at volumes greater than 580 mls.
Johnathon : clean the bottom of your motor surgically clean and continually monitor and eventually it should declare itself. Just keep your hands and garments away from the chain. Make sure all the case bolts holding the tranny cover are on. Clean the pedal shaft and realize there is a cheap metal cover over the shaft. If those guys also pulled the cover to inspect the clutches , the pedal shaft seal can be violated because even with the cover the exposed pedsl shaft can deteriorate and tear that seal. It might be hard to see a leak there. If it were the left sided shaft mentioned above , the drive chain should look over lubed.
Some kind of gouge at the drain plug could maybe leak there.
Somebody claims to be a moped shop charges for service , potentially screw s it up and refused to reevaluate. Wow!! That's why mopeds are so at the margins.
  Tomos LX leaking transmission oilTopic by: Jonathon glatzer Jonathon glatzer 12/17/17 10:08AM
  Re: Tomos LX leaking transmission oilRe: Moped Lar (OFMC) Moped Lar (OFMC) 12/17/17 10:10AM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 12/17/17 10:15AM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 12/18/17 06:19PM
  Re: Tomos LX leaking transmission oilRe: Tomos Forever Tomos Forever 12/18/17 06:39PM
  Re: Tomos LX leaking transmission oilRe: Lia the Raven Lia the Raven 12/21/17 03:35AM
  Re: Tomos LX leaking transmission oilRe: Bad Cadillac™ Bad Cadillac™ 12/21/17 09:54AM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 12/23/17 08:42AM
  Re: Tomos LX leaking transmission oilRe: Tomos Forever Tomos Forever 12/23/17 12:02PM
  Re: Tomos LX leaking transmission oilRe: pat splat pat splat 12/24/17 11:41AM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 12/25/17 06:56PM
  Re: Tomos LX leaking transmission oilRe: todd amundson todd amundson 12/26/17 03:44PM
  Re: Tomos LX leaking transmission oilRe: Lia the Raven Lia the Raven 12/27/17 05:12AM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 12/27/17 04:24PM
  Re: Tomos LX leaking transmission oilRe: P D P D 12/27/17 09:17PM
  Re: Tomos LX leaking transmission oilRe: Maya What Maya What 12/29/17 05:18AM
  Re: Tomos LX leaking transmission oilRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/11/18 02:05PM
  Re: Tomos LX leaking transmission oilRe: Mikey Antonakakis Mikey Antonakakis 12/26/17 02:10PM
  Re: Tomos LX leaking transmission oilRe: Marc Friedman Marc Friedman 12/29/17 09:28PM
  Re: Tomos LX leaking transmission oilRe: Jonathon glatzer Jonathon glatzer 01/06/18 07:34PM
  Re: Tomos LX leaking transmission oilRe: Marc Friedman Marc Friedman 01/06/18 11:22PM
  Re: Tomos LX leaking transmission oilRe: pat splat pat splat 01/08/18 09:19PM
  Re: Tomos LX leaking transmission oilRe: Lia the Raven Lia the Raven 01/12/18 04:18AM
Click here to login.
