Tmmp av10 cdi timing mark
charles smith /
Can get spark outside but fouls immediately when installed with no pops. The le partie has both marks but the stock tmmp only has a timing mark on the flywheel and an oddball dot at about 3 o'clock also I removed the half moon. Everything is still stock as I was going to get it running first then see if it holds up.
Click here to login.
