Re: Motobecane Engine ID and CDI box question
Charlie Wonka /
Treatland has all the parts in stock. Crate motors are basically junk.
Doppler endurance crankshaft, Doppler 49cc kit, a AV10 cases, fag bearings and seals, Moby CDI, aftermarket CDI box, either a black gun pipe or go big boy with a Doppler pipe, 0.3mm to 0.35mm carbon fiber Reed, pbhg Reed.block, 19 mm pbhg with cable choke.
Doppler ER3 variator, Doppler clutch pulley would 11 tooth sprocket, 58 to 68 rear sprocket, new motor mounts, airfilter, love you to death 60mph.
CharlieEdited 1 time(s). Last edit at 12/07/17 12:56AM by jackmeoff.
Click here to login.
