Bing tuning things
Alex Frank /
So I have a 77 maxi N.
has a za with
Magnum head with stock kit (49cc)
15mm bing (put O rings everywhere to seal it)
Hi Flow filter
techno boss pipe
#83 jet
My problem is it stutters here and there.
I'll let it warm up a tad then get rippin and its great. however, if I give it partial throttle (warm or cold) it falls on its face as if real lean. full throttle is great up until I hit top speed (30ish I think) full throttle acts lean.. if I back off the throttle back down to about 75-80ish percent it'll continue to pull for a tad longer and maintain its speed. next jet up makes it 4 stroke, next jet down is too lean. y
camo wrap will be removed in the future (PO did it)
Click here to login.
