Re: Qt50 shaft drive failure
P D /
> Trevor Buonaccorsi Wrote:
> Yes! Thank you if those guys won't ship to Canada the part numbers and
> listing numbers are the same thank you
> BTW do you know what tool I need to remove the big hex screw that holds
> the pinion in place
I couldn't find a part # , but I did find this :
https://www.ebay.com/itm/Yamaha-QT50-Yamahopper-ring-pinion-bearing-set-w-tool-PW50-rear-differential-/172197619296
Click here to login.
