Re: 1980 Tomos (a3) Silver Bullet craziness
Born to be WillD /
yea just get some calipers and check. measure length, too long is OK as long's it's not crazy long.
then the things that matter are the ends and diameter. it likely has squared ends. measure. there are 2 common sizes: 1.6 and 2.6mm squares. French shit's in between to be a pain in the ass.
Unlikely, but you might also have a split end like dis:
always just measure!
if you're getting a whole cable and replacing the housing too make sure you get the same size threads on the ends. probably m10x1.
Click here to login.
