Re: 12mm bring repair throttle slide not moving smoothly.
Avery M. /
Either your throttle slide or carb body is not true..maybe both.
If you have another carb you could start switching parts to further test the actual cause...either way you'll end up sanding out the extra material.
I've had this happen in the past on a 12 bing, and it surprisingly took a lot of sanding effort to get mine to function right.
Pretty depressing when even stock parts fight you!Edited 1 time(s). Last edit at 12/01/17 10:43PM by electricave.
Click here to login.
