Re: NU50M Chewing Drive Belt
Guillermo Payet /
Replaced the driven pulley with this one:
https://www.treatland.tv/complete-gy6-clutch-driven-pulley-assembly-for-sco-p/scooter-clutch-variator-stock.htm
It required some creative thinking: I used an angle grinder to shave down the inner "cheek" by about 4 mm. Then pulled out the 25x17 needle bearing and replaced with two 24x15 bearings. Added two layers of 0.010" brass sheet to make the new bearings fit.
Click here to login.
