Re: Exhaust Wraps
P D /
> Ken Roff Wrote:
> > P D Wrote:
> > > Ken Roff Wrote:
> > > > Sloetwn Suv Stigmopeyass Wrote:
> > > > I'm leaving out the jetting of the carb, but that is also part of
> > how
> > > to
> > > > squeeze a little more HP's out of a small motor.
> > > So right !
> > > Clean crisp jetting through out the range makes a big difference !
> > > Be off a little bit and your bike’s a dog
> > Another good reason to run non-ethanol gasoline .
> > Usually a couple times a year I have to tear carbs apart and clean up
> > the leftovers of ethanol gas .
> All I have is horrible ethanol gas where I live and I don’t tear apart
> t nothing but I run bing, dellorto and mikuni that have little rubber
> parts other than the float needle and one of the carbs I believe doesn’t
> even have a rubber tip on the float needle,
> What I do to minimize that rubber tip from dissolving with the horrible
> e gas I have where I live is I shut off the gas about a half a block
> from my house to lower not quite empty the amount of fuel that’s in left
> the bowl.
Have you ever tried to separate the ethanol from the gasoline ?
I haven't , as I've usually had pure gas available in different parts of the country .
If I have to spend much time in a place that has only ethanol fuels , I'll give separation a good shot .
I've spent too much time and effort cleaning the yellowish crud out of different carbs . One carb bowl has been partially 'eaten' due to ethanol . It's still viable , but it's enough to convince me to be careful of what fuels I run in my bikes .
Here's a link to a separation test :
http://www.mcnews.com/mcn/technical/2012decethanol.pdf
Click here to login.
