Stupid Puch CDI box question(s)
I'm cobbling together a budget Puch build from spare parts and trying to use stuff I already have in the garage. My question is - is there any way I can use this CDI setup but use this CDI box instead?
I guess I'm just wondering if anyone has done it and if so, which wires went where.
If it's not possible, does anyone have a Pietcard 2041 sitting around?
Re: Stupid Puch CDI box question(s)
Yeah You just have the pietcard option, the other one Will not work. i use a ax100 CDI + high tension coil on my minarelli, it has a nice retarding curve, there are a lot of bigger Two stroke bikes that use these type of boxes (CDI +coil all in one) It should work in Any Two stroke... Its this or a hpi mini rotor sistem wich i cant afford (edited)
https://m.ebay.com/itm/Ignition-Coil-Plug-Cap-ASSY-for-SUZUKI-AX100/182809776862?hash=item2a904fd2de%3Ag%3AdN4AAOSwhzJZr0fU&_trkparms=pageci%253A23d8b7f4-bae2-11e7-ba9b-74dbd180cd98%257Cparentrq%253A5c923c4615f0aca47352f1a1fffccc4b%257Ciid%253A1 this is the link, just so You have one more option, you just need a one positive wire magneto coil, You plug that to this and thats It, but sometimes coils have different resistances (ohms) and some may not work (edited)
DrGeorgeTompson (Alan) /
If you dont already have it, dont buy that trash ignition party. Those are TERRIBLE stators and break an awful lot or fire every 180*, or just start shitting the bed and acting as a rev limiter. Why not get the Pietcard internal coil and keep a stock flywheel? that would make for a lot less headache and would be more reliable.
This is the coil i talk of https://www.treatland.tv/pietcard-CDI-internal-coil-3055-bosch-puch-p/pietcard-cdi-3055.htm (edited)
timing matters. that's all
Dave Scrod /
If you had read my original post, it says I'm trying to use stuff I already have.
Also, I know a lot of folks say those CDIs are junk but I've got three of them (two being used, one in a box) and have never had any problems. (edited)
