Honda NC50 Big Bore running question.
Rapid Rob /
The NC50 with the new DR racing big bore kit has started to stumble after running a few minutes. It starts right up, drives to my mail box a couple hundred yards away, most of the way is coasting downhill at idle. I park it and get the mail and then try to pull away. The engine stumbles and bogs down and I have to blip the throttle a few times and the engine picks up and runs the 1/4 mile back home just fine.
Straight fuel, filter is new ( and in the correct flow direction) and the fuel lines are full. Petcock strainer is clear. Air vent in the fuel tank cap is open.
I pulled the spark plug and the ceramic has a black carbon coating rather than a brown coating. Is this a jetting problem or is something else going on?
Spark plug is 4 months old.
Any ideas?
Delorto 15.15 using a #68 jet and Delerto air cleaner. 7,000 feet ASL.
  Honda NC50 Big Bore running question.Topic by: Rapid Rob Rapid Rob 10/20/17 04:59PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 10:00AM
  Re: Honda NC50 Big Bore running question.Re: P D P D 10/30/17 10:15AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 10:47AM
  Re: Honda NC50 Big Bore running question.Re: P D P D 10/30/17 11:14AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 05:53PM
  Re: Honda NC50 Big Bore running question.Re: P D P D 10/30/17 09:19PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 09:38PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 06:06PM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 10/30/17 06:58PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 10/30/17 07:11PM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 10/30/17 07:37PM
  Re: Honda NC50 Big Bore running question.Re: Jack Rutherford Jack Rutherford 10/31/17 11:29PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/01/17 10:10AM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 11/01/17 11:50AM
  Re: Honda NC50 Big Bore running question.Re: [\/] |=| [\/] |=| 11/02/17 06:39AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/02/17 09:40AM
  Re: Honda NC50 Big Bore running question.Re: [\/] |=| [\/] |=| 11/02/17 10:00AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/02/17 10:12AM
  Re: Honda NC50 Big Bore running question.Re: [\/] |=| [\/] |=| 11/02/17 10:23AM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 11/02/17 10:39AM
  Re: Honda NC50 Big Bore running question.Re: P D P D 11/02/17 10:45AM
  Re: Honda NC50 Big Bore running question.Re: [\/] |=| [\/] |=| 11/02/17 06:58AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/02/17 10:03AM
  Re: Honda NC50 Big Bore running question.Re: Jack Rutherford Jack Rutherford 11/02/17 11:31AM
  Re: Honda NC50 Big Bore running question.Re: P D P D 11/02/17 11:53AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/02/17 08:41PM
  Re: Honda NC50 Big Bore running question.Re: Jack Rutherford Jack Rutherford 11/03/17 08:55PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/03/17 10:47PM
  Re: Honda NC50 Big Bore running question.Re: Jack Rutherford Jack Rutherford 11/04/17 12:11AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/07/17 10:21AM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 11/07/17 10:44AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/25/17 09:34AM
  Re: Honda NC50 Big Bore running question.Re: Jack Rutherford Jack Rutherford 11/26/17 09:33AM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/26/17 05:09PM
  Re: Honda NC50 Big Bore running question.Re: Charlie Wonka Charlie Wonka 11/26/17 05:48PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/26/17 06:15PM
  Re: Honda NC50 Big Bore running question.Re: Charlie Wonka Charlie Wonka 11/26/17 06:29PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/27/17 12:03PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/27/17 12:56PM
  Re: Honda NC50 Big Bore running question.Re: DPC Ryan DPC Ryan 11/27/17 06:19PM
  Re: Honda NC50 Big Bore running question.Re: Rapid Rob Rapid Rob 11/27/17 06:25PM
  Re: Honda NC50 Big Bore running question.Re: P D P D 11/27/17 07:12PM
Click here to login.
