Tomos bullet..help no spark
Hello, I have an 89 Tomos..just got it ..no spark..the run switch was missing the button so I jumped the black (power)..Hot when I kick it over..and brown wire..when I put my testor in the spark plug boot it lights up..but no spark at the spark plug..that's with new plug..any ideas?.. thanks so much!!!!
Re: Tomos bullet..help no spark
Clean the points.
Make sure browns are grounded. Had same problem and it ended up being the coil wasn't grounded. Mounting bracket was mounted to painted surface on engine case. Mine is black. Scraped the paint off and remounted coil. Spark!!!
dont have a bullet but the kill switch usually grounds the spark/coil thus killing motor.
