Moby dies with a little throttle
New weird problem. Recently installed the Treats CDI so I'm not sure if it's related.
Bike starts up very easy, runs great for a few minutes, then dies if I give it any throttle. It'll still idle great and start right back up, but if I give it any amount of throttle, it just immediately dies again.
Not even sure where to start looking. Carb's clean, I believe I wired the CDI up correctly.
Re: Moby dies with a little throttle
Make sure you have the intake/carb connection tight. Sounds like an air leak.
Also if you haven't already.put in a new properly gapped spark plug.
There could be an air leak at the jug base gasket or head gasket. Check for tightness and leaks. don-ohio (:^)
try moving timing around
Russell Meyers /
Check your carburetor float level or main jet for contaminates.
Cool, I'll check all that. I think I have a new spark plug kicking around somewhere.
With the CDI, am I supposed to use a resistor plug or boot? I'm running the same plug/boot from when I had the stock points setup.
Dan (LandLordsMG/PSVMC) /
It's ideal to use a resistor plug or boot with CDI, but that won't keep it from running.
Did you use silicone on the stator plate mounting screws?? Those holes go straight through into the case so it's possible that you could be leaking from there.
> from there.
I did, I used it on the plate and on the screws.
Okay, that's good.
Yeah check your carb mounting area, could be lean as well
