Stripped fork bolts
Puch maxi front forks, they both just fell out on me. I can't unscrew the top bridge hex bolts at the baseplate. I'm assuming they are stripped inside, they spin fine but don't come apart. I can't reach them, they are too far up into the fork tubes.
Has this happened to anyone?
Best I can come up with is to cut the tops off of the bolts, hope the inner pieces fall out and get new hardware.
Ya?
Re: Stripped fork bolts
i would just upgrade to cheap Maxi EBR forks. If top bolts are stripped, who knows what else is wrong with them structurally.
I can't get the forks off without removing these bolts somehow. :(
I'll look into it
Sounds like whatever they are threaded into is spinning with the bolt. Maybe try an impact to spin them loose.
