Puch sudden loss of spark?
Out riding my Magdumb a few weeks ago - just cruising around town, not pushing it or doing anything stupid (well, besides riding a moped), when my motor suddenly shut off like I hit the kill switch. Low temp, no weird sounds, sputtering, etc., it just died.
Got it home and realized I have no spark. Threw in a fresh plug, still nothing.
Setup is Gila / HPI Mini Rotor w/ Trailtech 'Dial-a-brightness' voltage regulator. It had been running perfectly for over a year without any problems whatsoever so I suppose I was due for something like this.
Before I put my angry pants on, start ripping wires apart and buying a bunch of shit I may not really need from Treats, what might be the cause of this? (edited)
Re: Puch sudden loss of spark?
Were you running any resistance in your plug setup?
Dave Scrod /
NGK CR22 wire, resistor boot & BR7HIX plug.
If you haven't already make sure no grounds have vibrated loose. Also running a resistor boot in conjunction with an r-type plug is going to give a lot of resistance.
Dave Scrod /
Thanks, Chris.
Ground wires were the first thing I checked roadside and everything is fine. I keep my Magnum pretty clean and routinely check all that stuff too. My kill switch is just a small toggle and I have a spare so I'll probably try replacing that first just to rule it out.
I had been running with that NGK plug & wire setup for a a couple of years with no trouble. Maybe it's a dumb question but what would problems would too much resistance in the plug circuit cause? (edited)
Would just result in potentially too weak of a spark
Did Puchs have that safety thingy with the taillight bulb or brake bulb like the Tomos and other bikes have? don-ohio
Probably Fred /
No but he's talking about an aftermarket HPI ignition system anyway
Oh,yeah...right Ken. don-ohio
Dave Scrod /
HPI stator was fried. Got a new one, problem solved.
Thanks for reporting back,Dave! We need to see the solutions. don-ohio
Ѭ ɞŦЯʚOluv Ѫѫ /
> solved.
How did you figure that out? Testing for resistance between white and blue?
