puch 12v stator coil resistance reading?
just want to find if im shorting. reads 2.8, shoudn't be in 1's?
Re: puch 12v stator coil resistance reading?
Probably Fred /
I would think 1ohm would mean more possible shorting then 2.8 ohm resistance.
The less resistance the more the possible short but I don't know what the ohm value is for that coil
Double Trouble Dan /
Pretty sure the coil is in the good range. Depends on which coil.
https://vintagemopeds.files.wordpress.com/2013/03/puch-e50-engine-tune-up-sheet.pdf
cool!
i think resistance cap and br plug combined with rain....ill put it back.
do you guys know how that treats windings with ignition coil performs?https://www.treatland.tv/puch-peugeot-103-internal-ignition-coil-p/puch-peugeot-internal-coil.htm (edited)
