Re: Vespa. And Vespa.
Ninja . /
Put a rag on the transmission drive output shaft to protect it. I use a flat head screwdriver and use it as a lever to get that brake spring off…This will take some time to remove the spring. This spring isn’t remanufactured so make sure not to bend or break it.
