Re: Can not install cylinder rods!
Born to be WillD /
Vice grip is fine if you grab not on the threads directly. you can also demel a shallow slot in the end and screwdriver it in, or best option is the doublenut. just basically locking 2 nuts against each other so you can turn the whole stud in.
if it's not going in and stripped you can save it with a helicoil kit pretty easily, or drill it clean and tap to m7 and use m7 studs.
