Re: Can not install cylinder rods!
Dirty30 Dillon /
I think you mean studs. And if you clean the threads in the cases well, and the ends on the studs aren't bad, they should thread easily. To fully tighten them, use the double-nut technique, which is easier to google then for me to explain
