motobecane stalling when using brakes
Herm Gilliam /
Has anyone experienced their moby stalling when brakes are used, or when switching headlight on ?
Re: motobecane stalling when using brakes
Could be bad ground at tail light.
This is why French bikes are feared and reviled by some. they're super weird in a few specific ways and one of them (at least for me) is they somehow have some magicaly inter-relation between ignition and lighting that no one else does, I am ashamed to say I don't know how it really works, but it's real.
1st, is yours the 6v (pre 78) or 12v (3 coil post 78)?
Hah, I just looked for the diagram and 1st thing I found is this moby wiring diagram that appears to be explaining exactly the problem you're having.
Herm Gilliam /
yes its actually a 12v( 3 coil post) manufanturing date Feb of 1979 with separate brake & tail bulbs, runs like a champ, but when brakes are applied
it stalls
Some mopeds stall when brake bulb is burned out and you hit brake lever. don-ohio (:^)
Herm Gilliam /
Big thanks to Moped Army, Mopedlar,Born to be willd, & Don Ohio
found tail light filament blown, even though the bulb worked, and I made
a better Ground connection,
I'm certain it all started when i noticed the original brake light switch
had deterioated, and literally fell apart when i removed the rubber.
Thanks again
